TCS and TelePresence Server
Justin Pascal
Hi all,
Im planning to implement a solution to play a video once a customer joins an static conference in TPS.
1) Can i connect TCS to TPS and stream a video from TCS?
gvijendr
Yes Justin. It is possible for TCS to join into a static meeting on a TP Server. Make sure you mute the audio/video comin in from TCS in the TPS conference control.
TCS will capture the audio/video/presentation content and it can record and stream into different formats.
Can the TCS when joining the TPS call, instead of recording the call, TCS stream a video from Wooza, etc towards the TPS, so when other participants join they can see the video from TCS?
This video from TCS should be streaming in loop. (Like video announcement)
thanks for the fast response
