08-21-2013 05:49 AM - edited 03-18-2019 01:40 AM
I was wondering if there is any option to reduce the quality of a stream from the content server. I have three option Small / Medium / Large, a nd small uses 500kbps, I would like to reduce it to 250 or 300.
Is there any confirguration that I can apply to do it?
Thanks in advance
Solved! Go to Solution.
08-21-2013 11:04 AM
Hello Manuel -
On the "Site Settings" page under "Advanced streaming options", you can specify target bit rates for small and medium, large will always use the maximum.
08-21-2013 11:04 AM
Hello Manuel -
08-29-2013 04:59 AM
That is exactly what I was looking for.
Thanks!
