TCS with VCS
adamgibs7
Level 6
Level 6
Dears,
I am new to TCS and VCS, i want to implement  TCS which will receive stream from TP endpoint and it will push to appspace and then to DMP,
I am actually confuse in how many different scenarios we can use VCS, and which are the different device that it can inter operate. I want to learn first how VCS works without  CUCM.??and what type of devices it can register by which protocol.??
Patrick Sparkman
The only distribution outputs the TCS can support are:
  • Cisco Media Experience Engine (MXE) 3500
  • Cisco Show and Share
  • Podcast Producer
  • iTunes U
  • Streaming Servers (Windows Media, Wowza for Flash, QuickTime/Darwin)
Can see more details in the TCS 6.x Admin Guide on understanding distributions outputs.
As far as a comparison of VCS or CUCM, someone else that knows CUCM more in-depth than I do would have to help there.
The TCS supports the usage of the API, so depending on what you need, it might be possible with some effort.
API guide:
https://developer.cisco.com/fileMedia/download/5613cf46-586c-477a-89c0-ef4832c3c3f8
The VCS can handle h323 and sip, registrations, calls and the translation in between both.
CUCM is today more or less SIP-Centric, but you can combine it with the VCS or EXPRESSWAY.
For more info there, search a bit here in the board or via google.
Please keep this thread TCS only and if you still wonder about VCS vs. CUCM open a new
thread for that.
