12-17-2015 01:55 PM - edited 03-18-2019 05:20 AM
I'm having issue when adding the TCS on the TMS. The TMS don't accept the password. I used the same admin account password for the TCS when accessing the web interface.
Any clue?
Thanks in advance.
Solved! Go to Solution.
12-17-2015 04:19 PM
TMS uses the TCS API to communicate to the server, you need to set a password for this account within the TCS under Management > Configuration > Site settings. See the TCS Admin Guide for detailed instructions, note this admin guide is for release S7.0, but the configuration is the same for all versions of the TCS.
12-17-2015 04:19 PM
12-17-2015 10:28 PM
Thanks Patrick. I see, I should set the API enabled on TCS and set a password. I will try this once I get back to site.
Thank you for your help.
12-20-2015 06:37 AM
Hi Patrick,
Issue was resolved when I added a password for the TMS to connect to the TCS API.
thanks for your help.
