TelePresence Conductor Prime monitoring issue
Hello!
I've installed Cisco TelePresence Conductor on virtual machine (version 2.2) and try to add this server
in Prime Collaboration Assurance (version 9.5), but I see error about failure http authentication.
Http credentials are right 100% (I can successful to login on Conductor admin web page with the same credentials).
What is problem?
thobonho
Hi Sergey, make sure that the admin account has API access enabled.
Hello!
API access is enabled.
It could be that your conductor version is not yet supported then. I would need to check in our lab but latest admin guide for version 9.5 mentions that "Prime Collaboration supports Cisco TelePresence Conductor XC 1.2 in the standalone model. The cluster model is not supported."
I can confirm that XC 2.2 is not yet supported. Look at the following link:http://docwiki.cisco.com/wiki/Supported_Devices_for_Cisco_Prime_Collaboration_Assurance_9.5. Seems like highest compatible version is XC 2.0.
