06-28-2014 11:48 PM - edited 03-18-2019 03:07 AM
Hi everybody
We recently bought 3 Telepresence sx20 devices, I configured them to work with our (Asterisk) SIP server
the SIP configuration that I used is as following :
Default transport: UDP
Line: Private
Type: standard
URI: 1030@xx.xx.xx.xx
Login name: 1030
Password: xxxx
Proxy 1: xx.xx.xx.xx
Discovery: manual
OCSP Mode: off
the provisioning settings that I used :
Connectivity: Internal
HTTP Method: POST
Login name: 1030
Mode: Auto
Password: xxxx
Address: xx.xx.xx.xx
now the devices are working properly (dial and receive calls)
the problem is there is no video call (audio calls only) although all cameras are connected .
I tried to make video call using remote control and web interface without luck
so, did I miss something ???
any help will be appreciated
07-01-2014 08:27 PM
Have you got Video enabled in your Asterisk setup?
ie, modify sip.conf to add:
[general]
videosupport=yes
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
07-03-2014 07:13 PM
Please post the SIP messages from a sample call. It may be that one or both ends isn't sending video capability, etc.
