TelePresence TX9000 Factory reset
Dear community,
I am trying to do a factory reset on a TX9000 touch panel. Unfortunately i am unable to locate any support information for this. I hope you can help me!
I assume it Touch 8,if yes refer below video.
https://www.youtube.com/watch?v=9d2D8lox2_c
Response Signature
Hi Nithin,
Thank you. I saw that video. Unfortunately it is not the right model. The touch panel is a Touch 12. Part is CTS-CTRL-DV12.
It might be driven by the Codec-G2R's. I was able to perform a factory reset on those with the pin on the right side, but it does not bring the rest of the system to a factory state.
Kind regards
Try command utils system factory reset from Codec CLI.
Have a look on below link.
https://www.cisco.com/c/en/us/td/docs/telepresence/peripherals/cisco_touch/installation/installing_the_cisco_touch.pdf
Response Signature
