08-01-2015 06:23 AM - edited 03-18-2019 04:48 AM
1. DTMF is passing incorrectly
2. Gateway or gatekeeper is behind a proxy address
3. ????
I can't think of the third, can you help me?
Solved! Go to Solution.
08-02-2015 04:54 PM
A media termination point (MTP) is an entity that accepts two full-duplex media streams. It bridges the streams together and allows them to be set up and torn down independently. The streaming data received from the input stream on one connection is passed to the output stream on the other connection, and vice versa. MTPs have many possible uses, such as:
– H.323 Supplementary Services
Refer SRND: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/media.html#pgfId-1046314
-Terry
Please rate all helpful posts
08-02-2015 04:54 PM
-Terry
