TMS 14.1 SQL Server 2012 Compatability
msamadpour
Does TMS version 14.1 support SQL 2012 SP3 compatibility? SQL 2012 SP3 Always-On compatibility?
Any migration documents?
Thanks in advance!
Patrick Sparkman
TMS 14.1 only supports SQL 2005 (32-bit only), 2008 and 2008 R2 (32 and 64-bit), TMS 14.4 is the first release that supports SQL 2012.  Refer to the TMS Install Guides for server and software requirements.
