05-15-2013 09:08 AM - edited 03-18-2019 01:07 AM
Hi all,
i need some help...
I have a file based phonebook, which is just an Export of a Manual phonebook...
in the manage phone book source pages, i set it up, i click on view contatact tab, and there they all in all their glory
i then create a NEW phone book called "Exported" and a connect this phone book source, and it connects i then
while in the manage phone books pages, click on the view contacts tab, and there are NO contacts
its either a major bug, or me!
a note, im currently using tms as trial, as im trying to learn TMS on my own
thanks
mitch
05-15-2013 02:15 PM
Does the phonebook contacts have any contact methods? I not then you have to add this in order for the contacts to be displayed in the pb. Also check the phonebook source activity status.. Any errors?
/Magnus
05-16-2013 07:57 AM
yes, these all have contact methods
like i said, while in manage phone book sources, i can see the contacts
when in manage phone book, i dont
i created the file from an EXPORT of some manually entered contacts that work fine
0 ERRORS, every thing says 100% event sucessfull
you can try it youself... make like 3-4 MANUALLY entered contacts, give them each 1 contact method
then export that to a CSV file...
then import them into a new pb source
then try to connect that to a new phonebook
see if it works
thanks
mitch
05-16-2013 12:59 PM
