10-31-2014 07:13 AM - edited 03-18-2019 03:36 AM
We have a Polycom HDX 8000 running Release - 3.1.5-5568 in my mainly Cisco environment that has stopped sending connection details to my TMS server running 14.4.2. I'm not certain if it happened after upgrading to 14.4.2 but I was wondering if anyone has any suggestions how to reinitiate this communications? I could purge it from TMS and see if that helps, but I want to do that as a last option.
Darren
11-02-2014 04:25 PM
Hi Darren,
What is the status of the endpoint shown in the TMS now? Is it No HTTP/HTTPS response error? Have you checked to make sure all the required ports are opened and communication through them is proper? You need the following ports opened:
HTTP: TCP: 80: Inbound
HTTPS: TCP: 443: Inbound
HTTP: TCP: 80: Outbound
SNMP: UDP: 161: Inbound
API: TCP: 24: Inbound
If everything is opened and still you see these errors please collect a wireshark trace on the TMS when you do a force refresh on the polycom, what do you see in the traces?
-Deepti
11-03-2014 06:04 PM
Hi Darren,
We've had no issues here with our Polycom HDXs talking to TCS 14.4.2 following an upgrade - so it's not likely that it was the upgrade that broke it.
In addition to the ports listed by Deepti above, you'll also need port 3601 inbound to TMS from the endpoint for the Polycom Phonebook/Directory Service (assuming you provision phonebooks to the endpoint).
One thing you could try would be to Enforce the Management Settings from TMS to the endpoint. Open up endpoint in TMS, click Settings, then click Edit Settings, check the management server settings are the correct IP or domain name, and finally click the Enforce Management Settings button.
If you're using a domain name for the management address, check that the endpoint has a valid DNS server defined so it can resolve the server's address to communicate to.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
11-03-2014 06:10 PM
11-03-2014 06:19 PM
Are you doing a "Force Refresh" from the View Settings page, or an "Enforce Management Settings" from the Edit Settings page - it was the latter that I was referring to above.
Wayne
11-03-2014 06:34 PM
I meant Enforce Management Settings also. I just did it again, and made a call from the the Polycom's web interface. In TMS, when I clicked on the call status of the polycom, it showed that it was in a call, but the status at the top of the TMS navigator page showed Idle. I clicked Refresh page from within the call status tab, and the Status changed from Idle to In Call.
Then I ended the call in the polycom web interface, and checked the call logs in TMS, and it still does not show up.
11-03-2014 07:36 PM
On the endpoint are the call logs enabled?
11-03-2014 06:06 PM
