TMS 15.0 TMSDatabaseScanner - HTTP status 404
I am having intermittent issues on TMS system. Detailed in the TMSDatabaseScanner.txt I found the below. Not able to ascertain what this is referring to. Need to know if this has been seen.
--------------------------------Log Snippet-------------------------------------------------------------------------------------
2015-10-14 16:02:11,843 [TMSDBScanner-TMSDatabaseScannerService.Scanners.CucmCtsDataImporter] ERROR TMSDatabaseScannerService.Scanners.CucmCtsDataImporter -
System.Net.WebException: The request failed with HTTP status 404: Not Found.
   at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
   at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
   at Tandberg.TMS.SystemAPI.CUCM.AxlServiceBase.InvokeAndParseAuthenticationException[TInObject](AxlServiceBase service, String methodName, TInObject parameter, Guid& logGuid)
   at Tandberg.TMS.SystemAPI.CUCM.AxlServiceBase.ExecuteSqlQuery(ExecuteSqlQuery query, Guid& logGuid)
   at Tandberg.TMS.SystemAPI.CUCM.AxlServiceExecute.ExecuteSqlQuery[TResultRow](AxlServiceBase service, ExecuteSqlQuery query)
   at Tandberg.TMS.SystemAPI.CUCM.SharedFunctions.GetSupervisedSystemsMacAddressList()
   at TMSDatabaseScannerService.Scanners.CucmCtsDataImporter.ScannerLoop(CancellationToken cancellationToken)
Wayne DeNardi
There are a bunch of Database and service related issues with TMS 15.0 which have been resolved in TMS 15.0.1.  I'd suggest you upgrade to the newer version and see if you're still experiencing the same issues.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Wayne
