TMS 15.1 upgrade fails with .NET framework not detected
Mattias Widman
Anyone here that can shed some light on the following issue.
I have a TMS server running version 15.0.1 on a Windows 2012 R2 install. When trying to upgrade it to 15.1 the installer fails claiming that it can´t find the 4.5 .NET Framework.
Since it´s part of the OS and has been a requirement for TMS the last couple of versions I am pretty sure it is in there...
Any tips on how to solve this or is it just another bug?
Patrick Sparkman
I get the same error when trying to do a fresh install of TMS 15.1.  However, I performed a fresh install on two servers weeks before without any issue.  You might be hitting bug CSCux86484, which is the issue I'm facing, as I remember looking through the registry and noticed it said .NET 4.6 was installed.
Determine Which .NET Framework Versions Are Installed
11 Replies 11
Patrick Sparkman
Of course...
It´s running 4.6 but the strange thing is that I believe it has been running that since the server was deployed last summer because it has not been installed as an update (checked installed updates)...
So no easy way of uninstalling it :(
Thanks for the info...
Yeah, I'm running into the same issue, no easy way to uninstall 4.6 as I'm still trying.  Just as you, it isn't listed in the installed updates, but I know it's installed.
I am sure you are right. Might just wait for Cisco to catch up instead.
You may be waiting awhile, no telling when the next TMS release may be and if/when it will support .NET 4.6. Not sure if you can see my earlier reply as forums have been acting up and not showing some posts, but I found the update that installed 4.6 on my server and was able to uninstall it. So it's not that hard, just a bit time consuming.
I´m sure it is not that hard to investigate and remove it but as it stands I have 15.0.1 running on it working fine. Upgrade isn´t critical at this point.
But since this is going to become an issue I hope Cisco makes it a top priority since it only seems to affect the installer.
Just to let you know, .NET 4.6 is a part of a MS Update, just have to scour the Microsoft's website and find all the different possible KB updates that might install it - for me it was KB3102467.
Duplicate post.
seva
If use .Net 4.7 uninstall the update KB3186539
Remove 4.7 without installing a different version?
You need to:
1. Identify the .Net version that you run. Use this link.
2. Identify the KB corresponding to your OS. See example here for 4.7 and 4.7.1
3. Use the Add and Remove software -> Windows component to remove the identified KB. It will downgrade the .Net framework to the previous version.
4. Repeat 1-4 as needed.
