TMS email setting for vc call report and event alert
Bo Bo Aung
Dear All,
May I know TMS can be configured to send email to administrator when event occur like endpoint/ gatekeeper down or endpoint registration fail ?
Can also be configured to send monthly vc call report to administrator ?
If yes, may I know how to configure.
Thanks in advance.
Patrick Sparkman
Looking at the event notifications built into TMS (Systems > Event Notification Manager), there is one called "Gatekeeper Registration", should work for what you want, description is below.
System has registered or failed to register to a gatekeeper.
As far as the auto sending of reports to an administrator, don't think that is supported.
Hi Patrick,
Thank for information.
Best Regards
Welcome.
Don't forget to mark relevant replies as correct, so others behind you looking for similar answers will be able to find it easily.
