TMS IBM Domino Outbound Integration
Anas Hafez
Is it possible to send an email to IBM Notes Clients when scheduling a meeting from TMS without TMSXN from the SMTP Configuration in TMS and SMTP Configuration from the IBM Domino Side & is there any configuration guides describing how to do that (if possible) ?
Wayne DeNardi
Assuming you have your Domino server connected to a SMTP relay, then you can just point the TMS server at that relay too and they should be able to communicate.  There's not really anything special that needs to be configured, it's all just basic SMTP.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Thanks Wayne for your helpful reply but just as a confirmation that i understood what you said correctly, do you mean that we even don't need any configuration from IBM Domino Side like a SMTP Service Configuration or a User mailbox with the same mail address configured on TMS ?
