TMS Scheduler Secure Conference as default?
gfolens
Level 4
Level 4
In the TMS Scheduler in step 4 of conference scheduling there is a Advanced window where you can set bandwidth, password, secure, Display option to extend conference on Master,...
By default 'Secure' is not selected.
Is there a possibility to make this the default selection?
In TMS Configuration Conference Settings - TMS Scheduler Options - the Secure-option is not present.
Maybe this default settings can be adjusted somewhere else?
rgds, Geert Folens.
Jens Didriksen
Level 9
Level 9
This might be what you're looking for:
Administrative Tools > Configuration > Conference Settings:
Conference Create Options:
Set Conferences as Secure by Default: Yes/No/If Possible
/jens
Please rate replies and mark question(s) as "answered" if applicable.
The parameter: "Set Conferences as Secure by Default:" is set to "If Possible".
If you set this to "Yes" then conference where endpoints without encryption capabilities and voice only calls participate will fail.
rgds, Geert.
Setting it to "yes" will make the default selection "secure" in scheduler - and isn't that exactly what you are trying to achieve?
/jens
