02-02-2018 08:18 AM - edited 03-18-2019 01:50 PM
the guide for the tms (page 60, section: Regular Time Zone) shows some code snippets which Im having an issue replicating.
Basically whenever I set the timezone rules retrieved via getTimeZoneRulesById to a conference and try to save it i get the error: The specified time zone information is not valid.
Why cant I use these returned timezone rules?
try { // get booking soap service BookingServiceSoap bookingSoapService = ciscoTMS.getBookingServiceSoap(); // get default conference with bookingSoapService Conference conference = bookingSoapService.getDefaultConference(); // adjust start and end time to be in the future and duration of an hour Date now = new Date(); Date startDate = org.apache.commons.lang.time.DateUtils.addHours(now, 8); Date endDate = org.apache.commons.lang.time.DateUtils.addHours(startDate, 1); DateFormat dateFormat = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss'Z'"); dateFormat.setTimeZone(TimeZone.getTimeZone("GMT")); conference.setStartTimeUTC(dateFormat.format(startDate)); conference.setEndTimeUTC(dateFormat.format(endDate)); // its in the future so set state to pending conference.setConferenceState(new ConferenceState(com.avispl.symphony.cisco.tms.sdk.v15.booking.ConferenceStatus.Pending)); // set title conference.setTitle("Unit Test XX-" + now.getTime()); // get timezone rules TimeZoneRule[] timeZoneRules = bookingServiceSoap.getTimeZoneRulesById("Central Standard Time"); System.out.println("Timezone rules returned successfully, count:" + timeZoneRules.length); // set timezone rules conference.setConferenceTimeZoneRules(timeZoneRules); // save conference conference = bookingSoapService.saveConference.saveProprietaryConference(conference); // delete conference if no errors bookingSoapService.deleteConferenceById(String.valueOf(conference.getConferenceId())); } catch (Exception e) { System.out.println("Error: " + e.getMessage()); }
Output:
Timezone rules returned successfully, count:2
Error: The specified time zone information is not valid.
Solved! Go to Solution.
04-12-2018 11:38 AM - edited 04-12-2018 11:39 AM
the issue stemmed from the validFrom field
TMS is expecting 2007-01-01T00:00:00
But we are sending (including the ms) 2007-01-01T00:00:00.000Z
its a nullable field so thats what i did and now the above is working
FYI you really wouldnt know it without tracing it with something like wireshark
