01-16-2018 02:38 AM - edited 03-18-2019 01:46 PM
Hi all
I would like to know the meaning of 'CallLegs Active' and 'CallLegs Max Active'
which are found on TMS under cms system status.
Danny
Solved! Go to Solution.
01-16-2018 07:16 AM
CallLegs Active - number of active calls currently on CMS.
CallLegs Max Active - number of calls that has occurred during the duration of Call Bridge Uptime.
01-16-2018 07:16 AM
01-16-2018 05:53 PM
Thank you Patrick for your explanation.
