TMS, TMS PE, TMS XE and SQL support
dwilburn1977
My organization is looking to upgrade its SQL farm to SQL 2014. Questions are being raised about the compatibility of my systems with that version of SQL, yet I'm having trouble finding documentation, or a compatibility matrix, that shows what versions of SQL are supported with my systems.
Can someone point me in the right direction for documentation?
Thanks!
Patrick Sparkman
The install guides will tell you the required software versions that you'll need to run, currently SQL 2012 is the highest version supported, refer to the TMS Install Guides and TMS Extensions Install Guides. XE and PE don't list a specific SQL version, so you should go by what's documented for TMS, as most deployments usually install the various TMS databases on the same SQL instance anyway.
