TMS Unable to change SNMP Setting
carlnewton
Level 3
Level 3
Guys,
Im trying to change the SNMP community string for a Conductor entered into TMS, as its incorrect.
All my other devices allow me to change the SNMP string but for the conductor it is greyed out and I cannot edit it.
They system is moaning the SNMP String is wrong (Which it is) but wont let me change it.
I dont want to delete and re-add the conductor as it has various settings I'd like to keep.
Has anyone else experienced this?
Patrick Sparkman
It's not possible to update the community name from the Settings tab for Conductor within TMS, however you can change the community name on the Connection tab.
Patrick Sparkman
Yes it is possible:
Settings found in Administrative Tools > Configuration > Network Settings
This is a comma separated list of common SNMP community names Cisco TMS will use when discovering and adding systems to Cisco TMS. If you use a customized SNMP Community Name on your existing systems, be sure to add it to this list.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/admin_guide/Cisco-TMS-Admin-Guide-15-5.pdf
LBachman
