TMS upgrade error code 1902
Bob Fitzgerald
Level 4
Level 4
Hello!
Running into an issue with a TMS14.2.x upgrade.  The upgrade keeps bombing out when updating the database.  Originally it was from having null values in PlannedEndTime.  After running the script to fix that the customer is running into a new error;
Error Code 1902 at line 1: Cannot create more than one clustered index on table 'dbo.AclUser'. Drop the existing clustered index 'ix_clust_temp' before creating another.
Is it simply a matter of deleting the existing 'ix_clust_temp' and running the installer again?
Thanks!
Zac Colton
I believe I have ran into this before. What I did was put a SQL query together to clear out the statistics so that they can be rebuilt correctly. Like any other action that does a delete. Be sure to get a solid backup of the database before anything like this is attempted.
DECLARE @ObjectName sysname
DECLARE @StatsName sysname
DECLARE StatsCursor CURSOR FAST_FORWARD
FOR
SELECT
'['+OBJECT_NAME(object_id)+']' as 'ObjectName',
'['+[name]+']' as 'StatsName'
FROM sys.stats
WHERE
(INDEXPROPERTY(object_id, [name], 'IsAutoStatistics') = 1
OR INDEXPROPERTY(object_id, [name], 'IsStatistics') = 1)
AND OBJECTPROPERTY(object_id, 'IsMSShipped') = 0
OPEN StatsCursor
FETCH NEXT FROM StatsCursor
INTO @ObjectName, @StatsName
WHILE @@FETCH_STATUS = 0
BEGIN
EXEC ('DROP STATISTICS ' + @ObjectName + '.' + @StatsName)
END
CLOSE StatsCursor
DEALLOCATE StatsCursor DECLARE @ObjectName sysname
FOR
SELECT
FROM sys.stats
WHERE
OPEN StatsCursor
BEGIN
END
CLOSE StatsCursor
Bob Fitzgerald
Level 4
Level 4
Hello again!
Since I am unversed in SQL would someone have the queries to locate and/or delete 'ix_clust_temp'?
Thanks!
Zac Colton
FOR
SELECT
FROM sys.stats
WHERE
OPEN StatsCursor
BEGIN
END
CLOSE StatsCursor
FOR
SELECT
FROM sys.stats
WHERE
OPEN StatsCursor
BEGIN
END
CLOSE StatsCursor
Hey there Zac!
Thanks for this.  We'll try this out and I'll let you know how it went.
Have a great weekend!
Hi Zac,
That did the trick.  Thank you very much for the info.
