TMS User Provisioning -- Speed UP Automated AD Polling
Michael Boscia
Level 4
Level 4
Is there a way to get TMS to poll the AD tree more often than every 24 hours for user creation purposes?
Magnus Ohm
Hi Michael
It's not configurable as far as I know, but if you look for a way to do it I think you can modify the event in the SQL database however i wont confirm that until i tested it, and i do not believe its officially supported, but possible? It might be
I think its in the scheduler event table but as I said i need to check it out unless anyone else beats me to it
/Magnus
adimchev
Hi Michael,
the sync schedule cannot be changed for the time being
