TMS VM Requirements
Have a customer that needs to move the TMS 14.2 VM from their IMB blade chassis to their new B-series Chassis.
I am a little concerned about the CPU requirements of needing two 2.6 GHz processors.  We have available a B200-M2 with dual E-5649 processors that are clocked at 2.53 GHz.
The number of devices supported is less than 20 end points and we are not doing TMSPE nor Provisioning for any soft clients.
Should I be worried or only if they decide to go crazy with Jabber clients?
Magnus Ohm
You should be fine with that imo.
/Magnus
