TMS with WebEx Prod Tool integration receiving error message There are not enough resources available to host this conference
peters4127
TMS with WebEx Prod Tool integration receiving error message There are not enough resources available to host this conference.  If WebEx is removed the error disappears. Does anyone know the solution to this problem.
Patrick Sparkman
Is this a CMR Hyrbid deployment, or something else?
Can you tell us more about your environment.  Please provide as much detailed information as possible, just saying something isn't working, doesn't tell us enough information to be able to help.
What conference bridge are you using, ie: MCU, TelePresence Server, CMS?
Is the conference bridge you're using set to "Allow WebEx Booking" under it's Settings wtihin TMS?
