Which VCS Expressway Do I Buy
DamianRC
Advanced thanks.
I currently have a VCS control 8.7.1(CE 1100 appliance).
I need to purchase an Expressway for in and outbound external calls.
Which Expressway do I purchase, C or E. E seems the right choice, but I'd like to be sure.
Thank you
Patrick Sparkman
If you already have a VCS-C, then you need to purchase a VCS-E, refer to the VCS Data Sheet for more information.  Because you already have a VCS-C running on the CE1000 appliance, if you want the VCS-E to run on it's own CE1000 appliance as well, you'll want part number VCS-E-BDL-K9.  You also have the option to run your VCS-E as a virtual appliance as well with VMWare, that part number is R-VMVCS-EXPWY-K9.
Patrick Sparkman
Thank you, Patrick.
I'm targeting the VCS-E-BDL-K9.
