tmspe - Failed to create device template
Danny Meyer
Level 4
Level 4
Hi everybody.
I wanted to upgrade an existing TMS 13.2 installation for enhanced provisioning.
The migration tool fails with the following error:
Start migration of 2 device templates...
19 Nov 2012 21:29:39 ERROR - Failed to create device template for {id=[4de6f381-6322-4e86-993e-33d26b418fda], display_name=[movi], uri_pattern=[movi.{email}], type=[VIDEO_ENDPOINT]} URL: /device_templates The exception returned from API was Invalid placeholder: email Status: InvalidPlaceHolder Status Code: 2303 Data: {invalidPattern=email}.
The exception message is: POST http://localhost:8788/fm/device_templates returned a response status of 400 Bad Request
19 Nov 2012 21:29:39 ERROR - Migration failed
There was a similar thread with an issue with groups, but this does not help for this case, I tried this fix.
Does anybody has a hint for me what I need to (probabely) delete prior to the migration?
Many thanks in advance
Danny
6 Replies 6
awinter2
Level 7
Level 7
In your provisioning directory, have you defined any device URI patterns referencing '.movi.{email}'?
The migration tool seems to have a problem with this since {email} is not a valid user field mapping, you should replace the device URI mapping with {emailAddress} instead since that is the correct field mapping for the e-mail address property of the provisioning user.
Andreas
Hi Andreas.
Thanks very much for your quick answer.
I have deleted any mappings in the parent folder for the users that exist (according to the the similar post).
Have I missed maybe something?
Thanks and regards
Danny
Danny,
my guess would be that the reference to {email} is found in one of the devices defined in your FindMe template configuration, specifically in the device template for Movi inside your FindMe template, so you might want to take a closer look at that.
Andreas.
You saved my day, many thanks. It was indeed in a findMe template, but not as {email}, but with
{emailAddress}. I changed it to username.movi to be on the safe side, and it worked !!!!
Can I put it back? :-)
Kind regards
Danny
Magnus Ohm
The email placeholder was never implemented for the findme template. There is a feature request open for this. In the mean time if the e-mail address is firstname.lastname@domain.com you can create this pattern movi.{first_name}.{last_name}@domain.com or {username} if that is applicable. For the device pattern you can use the {email} placeholder.
/Magnus
Magnus.
Thanks for your clarification. That's indeed not a big problem to compose in case.
I am happy that the conversion worked and let's not wonder why "emailAddress" was initially allowed to enter there.. :-)
Cheers
Danny
