11-04-2013 09:17 AM - last edited on 03-25-2019 09:10 PM by ciscomoderator
In the process of migrating from legacy TMS agent to TMSPE 1.0 I was prompted to install Java 6 on the Win 2008R2 server. Will also be upgrading TMS to 14.2.1 and TMSPE 1.1.
Since Java 7 is the most current version I would prefer to install that. Are TMSPE 1.0 and 1.1 compatible with Java 7 or do I have to stick with Java 6?
Mike
Solved! Go to Solution.
11-04-2013 09:39 AM
Mike -
TMSPE 1.0
TMSPE 1.1
See the prerequisites and recommendations of both guides for more details.
I would stick to the recommended version of Java for whichever version of TMSPE you plan on installing at that time.
11-04-2013 09:39 AM
Mike -
TMSPE 1.0
TMSPE 1.1
11-04-2013 10:03 AM
Thanks Patrick,
I think I have an older Java 6 version in that range.
Appreciate the prompt response....
Mike
