TMSPE & Java compatibility
mpitts
In the process of migrating from legacy TMS agent to TMSPE 1.0 I was prompted to install Java 6 on the Win 2008R2 server.  Will also be upgrading TMS to 14.2.1 and TMSPE 1.1.
Since Java 7 is the most current version I would prefer to install that.  Are TMSPE 1.0 and 1.1 compatible with Java 7 or do I have to stick with Java 6?
Mike
Patrick Sparkman
Mike -
TMSPE 1.0
TMSPE 1.1
See the prerequisites and recommendations of both guides for more details.
I would stick to the recommended version of Java for whichever version of TMSPE you plan on installing at that time.
Patrick Sparkman
Mike -
TMSPE 1.0
TMSPE 1.1
Thanks Patrick,
I think I have an older Java 6 version in that range.
Appreciate the prompt response....
Mike
