TMSXE 3.0 recommended install location
arawnmediagroup
As I understand, TMSXE 3.0 is to be installed on a separate server from Exchange. Should it be installed on TMS server or different server altogether? TMS is appliance ver.
Thanks in advance.
From the Cisco TMSXE installation guide, "Deployment Best Practices" section:
We recommend installing Cisco TMSXE on a standalone server.
Cisco TMSXE may be co-located with Cisco TMS in smaller deployments, with the following prerequisites:
  • The server must have a minimum of 4GB RAM.
  • A maximum of 50 telepresence endpoints are available for booking in Cisco TMS and Cisco TMSXE.
Kjetil Ree
TMSXE 3 is a 64 bit application. As the TMS appliance server is 32 bit, you'll have to install TMSXE somewhere else.
-Kjetil
Ah right. Where are companies installing this? They are not dedicating one server to TMSXE.? I guess that is where I am confused.
Thanks for your time.
Thank you.
