TMSXE and Outlook calendar item daylight savings time
bmcdonald
We have TMS 14.1.1 and TMSXE 3.0.2 connected sychronizing to Exchange 2010 calendars.  Bookings that are recurring that span March 10, 2013 are being incorrectly adjusted ahead by 1 hour in the Outlook resource calendar.  Users book the tms using Outlook.
Anyone have input to correct?
Magnus Ohm
This is a known bug and should be fixed in the upcoming versions of TMS/TMSXE
/Magnus
Yes we are aware of the upcoming patch.  However in the meantime this "bug" is quite damaging causing us a lot of manual handling of our calendar bookings.
Any idea when this patch is due out?
Full time zone support in TMS scheduling has been implemented in TMS 14.2 / TMSXE 3.1, both scheduled for release in mid-April. This will take care of your problem (i.e. that instances of recurrent series that span a DST shift are shifted one hour after DST is in place) and all other similar problems/limitations in the current products.
Kjetil
TMS 14.2 and TMSXE 3.1 have now been released. They are available on CCO (cisco.com).
-Kjetil
