03-25-2015 03:04 PM - edited 03-18-2019 04:14 AM
When running the TMSXE configuration wizard I am unable to connect to TMS by using its VIP FQDN. If I use each tms server name individually it works, but not when using the cluster name or VIP address (behind F5 NLB)
I can connect to TMS website using the FQDN of the VIP
Not sure what else to check. Any help would be appreciated.
Note: All applications are running on different Windows Servers, same VLAN.
Solved! Go to Solution.
03-30-2015 06:39 AM
Hi Frank,
Please let me know is it not connecting or there is an issue with authentication.
Have you tried accessing tms on tmsxe server web interface, did it worked?
Vivek
03-30-2015 06:39 AM
Hi Frank,
Vivek
03-30-2015 06:49 AM
Hi Vivek,
I was having a connections issue from TMSXE to TMS (on same vlan) but it has been resolved.
Thank you,
