TMSXN upgrade from 11.3.1 to 11.3.2
jtoque
Hello community.
We are about to upgrade TMSXN from 11.3.1 to 11.3.2 and we have the following questions:
- Is TMSXN 11.3.2 compatible with Domino 8.5.3 FP5 ? We can see that Domino 8.5.3 FP3 is not supported, we hope this limitation does not apply to later FP ("...8.5.3. FixPack3 for the Lotus Domino has a known issue and deletes a series of files from Cisco TMSXN and is therefore not supported...")
- Is it mandatory to modify user's mail template ? Or is "tmsmail85.ntf" the same as the one shipped with TMSXN 11.3.1 ?
Thanks a lot for any help.
Julien.
jtoque
FP5 is a newly released version to which testing is still being done as we speak...
FP3 has a bug in the setup file, deleting TMSXN files when already installed, i don't know the bug id and i don't know if FP5 fix the issue....
After research, no change on "tmsmail85.ntf" when upgrading to TMSXN 11.3.2 (from 11.3.1).
J.
