To configure ttc8-02 standalone as webcam
shayamsiri0
Hey, I'm struck with the ttc8-02 camera which doesn't have a codec, so I want to configure it as standalone camera for WebEx meetings. It needs to connect to a Samsung TV. (Not Android supported). I need a suggestion on which Visca software to use.
The camera is not designed to be used this way, and the cost of making it do so (especially if you want to have camera control) will likely cost you more than a suitable replacement camera.  If you do a search in this forum you'll see many posts on this same topic as it pops up quite frequently.
The commands that are available for the cameras are also documented in Chapter 6 of the PrecisionHD 1080p-720p Camera User Guide.
There is a github project that may assist you: GitHub - foxworth42/arduino-VISCA-controller: Arduino based VISCA controller for Cisco TelePresence Precision series of cameras
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
