Touch 10 camera control obscured
Oleg Serstjuk
We have a webex room kit pro with 5 cameras, when you select self-view option, you have the dropdown options to choose each camera to adjust, the problem we have is that the option for camera no.5 is not fully visible (only about the top 1/5 is seen and the text is not visible)
Touch 10 basically doesn’t have the room to display all 5 options, so it should either scale the size of the buttons or have a scroll option in place to see the rest of the button
Any ideas if there is a setting to change the text or scaling options on the touch 10?
0 Replies 0
