10-19-2018 07:10 AM - edited 03-18-2019 02:24 PM
Can anyone suggest on the different hardware versions available for Touch 8.
Does all the hardware versions supported by TC software.
10-21-2018 07:38 PM
Some of the newer hardware versions are not supported on the older software versions, but I wouldn't recommend that you contine running the old TC5 end of support software anyway.
There is a table in the TC7 release notes which details which of the newer TANs have a minimum software release.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-21-2018 08:52 PM
10-21-2018 10:03 PM - edited 10-21-2018 10:07 PM
Did you look at the document I linked in my previous email - in particular at the table on page 78 in the section titled "Cisco TelePresence Touch 8 hardware dependencies".
The software version is really only an issue if you're running a software version on the endpoint that is less than TC5.1.4, which is not recommended for many reasons, but there are some other small differences between which TANs are supported on which System types with the early model hardware.
10-21-2018 10:08 PM
Hello Wayne,
I looked in the doc.. and it only shows the TAN number.
Can you pls help and share the keywords for Hardware version for Touch 8 like mentioned for Touch 10 example : 102300-3.
So that we can identify the same through the Codec GUI.
10-21-2018 10:57 PM
The TAN is the physical hardware version. That is the number you will need to look at.
For the older hardware there is no way of seeing the exact hardware version through the web interface of the endpoint as you can do with the newer hardware. You will need to physically identify them.
