Touch Panel 8
zidjali2007
Dear
I have a problem with Handset which is connected to Touch Panel. It is detecting on the touch panel but the problem If I am using speaker both side can hear each other. If I used handset the caller can hear the other side but other side which received the call can't hear the caller. Is this configuration issue or hardware issue.
Elias Sevilla Duarte
This not a configurable value. When you lift the handset offhook, the audio and microphone are automatically selected, or by choosing the handset from the touch panel interface. If this does not work when in a call, and the far end does not hear the near end, then you are seeing a hardware failure. Here is what it says the admin guide.
"The handset is automatically selected when you lift it off the hook. Only the microphone in the handset is enabled. Neither the internal microphone nor an external microphone can be used."
You might need to open a TAC case to get the part replaced.
