Touch Panel - Discover IP Address Remotely
out4golf
Is there any way to find the IP Address of a paired Touch Panel, without being on site?   I don't have access to the network switch.
Anurag Srivastava1
Are you able to access the codec?
 If Yes then you can login through Web GUI and navigate to configuration-->peripherals
And it will show you the paired touch panel status.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
