TOUCH SCREEN SHOWING UP ON LEFT MONITOR?
Chet Cronin
Level 4
Level 4
I have a MX700 Dual setup with Ce9.15.15.4 installed.
My issue is (I hope simple fix).   System running Ok but noticed today when I connected a laptop via PC(HDMI) port that the touch panel indicated the LAPTOP is connected.  When in a call I select Share and the LAPTOP shows up on both monitor?
I did not select either the Preview or Share in a call button ?
When I selected Preview it still shares in a call plus what is strange is the screen on the touch panel displays on the left monitor in the halfwake and I can see under the touch display the LAPTOP and participants on both monitors.
Normally I would see the laptop on one monitor (preview) and when shared on one monitor and would still be sharing.
I restarted the system and no change.
Was wondering if there is a bug in 9.15.15.4 ?   I am using the touch 10 touch panel with the MX700.
Any ideas ?
Cabling appears to be good.
Thanks.
Chet Cronin
0 Replies 0
