TP,Cube to Cube video call
Bar1s
Hi everyone,
I need some advice,
I have two side;
First; CCM 6.1.5+CTMS(Cisco TelePresence Multipoint Switch)+Telepresence 1000+Cisco 3845(c3845-adventerprisek9_ivs-mz.124-22.YB8.bin).
Second; CCM 8.5+CTMS+TP 1000+3945 (3900-universalk9-mz.SPA.150-1.M4.bin).
I trying video call over cube to cube. I did some configs but will try tomorrow J.
I need some anwers:
  •        3845 router doesnt have pdvm, pdvm that mandatory for cube calling ?
  •        3845 router is there need license for cube?
Here is the configs;
3945 router config------------------------------------------------------
voice rtp send-recv
voice service voip
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0.21
  bind media source-interface GigabitEthernet0/0.21
  early-offer forced
voice class codec 1
codec preference 1 aacld profile 1
video codec h264 profile 2
encapsulation dot1Q 21
ip address CUBE3945 I_WANIP
ip forward-protocol nd
ip http server
no ip http secure-server
codec profile 1 aacld
fmtp "fmtp:96 profile-level-id=16;streamtype=5;mode=AAChbr;config=B98C00;sizeLength=13;indexLength=3;indexDeltaLength=3;constantDuration=480"
codec profile 2 h264
fmtp "fmtp:112 profile-level-id=4D0028;sprop-parametersets=R00AKAmWUgDwBDyA,SGE7jyA=;packetization-mode=1"
dial-peer voice 1 voip
description to_CCM85
service session
rtp payload-type cisco-codec-fax-ind 110
rtp payload-type cisco-codec-aacld 96
rtp payload-type cisco-codec-video-h264 112
session protocol sipv2
session target ipv4: CCM85_IP
incoming called-number 10........
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2 voip
description to_CCM615
service session
destination-pattern 7.......
session target ipv4: 3845cube_wanIp
voice-class codec 1
dtmf-relay rtp-nte
3845 router config------------------------------------------------------
voice service voip
media flow-around
sip
  bind control source-interface GigabitEthernet0/1.21
  bind media source-interface GigabitEthernet0/1.21
  early-offer forced
voice class codec 1
ip address CM6_wanIp
description to_CM8
service session
destination-pattern 10........
voice-class codec 1
session target ipv4:3945_wanIp
dtmf-relay rtp-nte
description to_CM6
service session
voice-class codec 1
session target ipv4:CM6_IP
incoming called-number 7.......
dtmf-relay rtp-nte
Best, thanks..
Paul Anholt
Hi Barris,
Try adding the following configuration:
voice service voip
rtp-ssrc multiplex
address-hiding
sip
  midcall-signaling passthru
  session transport tcp
  header-passing error-passthru
  pass-thru content sdp
  rel1xx disable
Paul
Paul Anholt
Hi Barris,
voice service voip
rtp-ssrc multiplex
address-hiding
sip
  rel1xx disable
Paul
