Troubles with camera PHD 12xs
IvanEfremov
I have SX-20 codec with ce 9.9.0 46f7ea38fda software. and PrecisionHD 1080p 12X with 40083 software. When i plug cables in camera, it starting update to version 40085, and just shutting down. Logs on codec tells:
2019-12-16T15:36:40.887+03:00 appl[2763]: CAMERA I: =======================================
2019-12-16T15:36:40.887+03:00 appl[2763]: CAMERA I:        Camera SW upload started
2019-12-16T15:36:40.887+03:00 appl[2763]: CAMERA I: WARNING:
2019-12-16T15:36:40.887+03:00 appl[2763]: CAMERA I: Camera is being upgraded.
2019-12-16T15:36:40.887+03:00 appl[2763]: CAMERA I: Do NOT switch off the system!
2019-12-16T15:36:40.977+03:00 appl[2763]: CuilApp[1]: User root/osd about to execute command '/Audio/Sound/Play Loop: Off Sound: Notification' from localhost.
2019-12-16T15:36:41.059+03:00 appl[2763]: CAMERA I: [*                               ]
2019-12-16T15:36:45.134+03:00 appl[2763]: CAMERA ERROR: Packet: 0xc Flash write error
2019-12-16T15:36:45.135+03:00 appl[2763]: CAMERA ERROR: Camera SW upload: Loading aborted
 what i need to do? can i cancel software update? or somehow format flash drive on camera?
Wayne DeNardi
If the camera keeps failing to upgrade then it is likely faulty and you should log an RMA through the Cisco TAC.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
