10-06-2020 12:23 AM
Hi All,
need suggestion /statements
TMS 15.6.0 installed (due to some factors sticking to old version )
Unable to added TPS 4.1(2.33) on Tms 15.6.0 over http mode
Every time i add the TPS is communication on Only Https and looking for SNMP string.
Any suggestions, if its even supported ?
10-06-2020 06:12 AM
Not 100% certain, but I think you need to enable SNMP on the TPS for TMS, I don't think it support https only. I'd try that.
10-06-2020 07:05 AM
Hi Patrick,
TPS does not have the SNMP option (at least on the stated version neither it has the option to enable Secure web)to be set and its communicating over Http/Https.
TMS guide says it will by default communicate over Http/Https but i never see it communication over Http.
Thank you for responding.
