06-21-2012 02:33 PM - edited 03-17-2019 11:21 PM
Hello People,
You can tell the difference between:
L-95-85-MS
Order L-MXP-PAK for E-deliveryof Edg95/85MXP NPP Upgrdeto MS
and
L-EDGE-MS
Order L-MXP-PAK for MS Upg for Legacy Edge systems
*Required update MXP95
**NPP license is required?
Thanks!
Solved! Go to Solution.
06-21-2012 04:27 PM
MXP Endpoint has three "feature" option statuses.
1) Standard - no option
2) NPP - Enable NPP feature
3) MS&NPP - Enable both Multisite and NPP feature.
Because MXP Endpoint able to configure only one feature key, when you install MS option key, it actually enable NPP feature in same time.
So purchase MS option key will not require for purchasing NPP license separately.
Please note, above is not apply on C-series Endpoint.
C-series Endpoint support installing multiple feature option keys and able to install multisite (MS) and NPP option key separately.
06-22-2012 06:53 AM
Hi Rafael,
From your post above, the MS option looks like MS-EDGE.
Mubashshir Akhtar
06-21-2012 04:27 PM
06-22-2012 06:22 AM
OK for NPP! o client already has!
But, what is the part number I purchase? L-95-85-L-MS or MS-EDGE to enable MS?
Tks!
06-22-2012 06:53 AM
Hi Rafael,
Mubashshir Akhtar
06-22-2012 07:00 AM
Thank you all
