04-04-2013 04:32 AM - edited 03-18-2019 12:52 AM
Dear all
I ahev a general questions regarding the Migration from TMSXE 2.3.1 to 3.02 with Excahnge 2003.
Is there a problem to do that? or could be maybe a risk that I'm loose all my Calendar entry on the Exchange?
Is it also possible to make an upgrade to 3.02 in the follow way:
1. Detach the Room mailbox (on 2003) -> no longer synchronise the Calendar to TMS
2. Uninstall the TMSXE 2.3.1
3. Now I'm clear all booking Resource on the TMS
4. Move / Convert the Room Mailboxes to Exchange 2010
5. Installing TMSXE 3.02
6. Installing/Configure TMSXE 3.02 as clean Installation
7. Configure the VC System with the associated Room mailbox (Exchange 2010)
Now the existing Calendar Entry are synchronis with TMS should beo OK.
Any input appreciated for my Querstions.
Best regards
georg
Solved! Go to Solution.
04-04-2013 05:12 AM
doing a migration from 2.3.1 is possible and the process should be documented in the TMSXE installation guide:
/Magnus
04-04-2013 05:12 AM
/Magnus
04-04-2013 05:29 AM
Hi Magnus
Thanks for the that, i know the Docuemnt and I have also readed.
For me was the Questions can I do that also without Migration, because I have only 4 Systems, but I'm would not loose entry on the Exchaneg calendar.
georg
04-10-2013 03:20 AM
Hi Georg, I concur with Magnus, as the process documented in the TMSXE installation guide has been tested by our experts and will be easier to migrate.
BR, Mahesh Adithiyha
04-10-2013 10:45 PM
Hi Mahesh
Yes the Upgrade was succesfull without any Problem.
It was the first time to Upgrade from 2.3 to 3.x, that was the reasn I'm a little bit carefully.
Thank you.
Best Regards
Georg
04-10-2013 11:04 PM
Hi Georg, Thank you for sharing the update.
