Using LCD-100-Pro-40N as an external display
t.takemoto
Hello. I'm installing CTS1300 and using LCD-100-Pro-40N as an external display.
When I previously use third party LCD(NEC LCD), I used DVI to HDMI cable between TelePresence and external display.
Does LCD-100-Pro-40N also need DVI to HDMI cable? Or is HDMI to HDMI cable available since both are Cisco brand?
harshdaftary
Both cables can work but Cisco recommend DVI-HDMI cable between codec and an external display.
Cheers,
Harsh
harshdaftary
Cheers,
Harsh
Thanks for your advice.
I confirmed that HDMI-HDMI works.
For your information, when I installed a NEC LCD, HDMI-HDMI didn't work. HDMI-DVI was the right cable.
