VCS Control and VCS Express Integration
Anju Josua
Dear All,
Right now, i am deploying VCS control and express. I am using H.323.
My topology as below :
VCS- C (local IP: 10.170.11.43) <-----> VCS - E (local IP: 10.170.10.44 NAT to 1.2.3.4) <----->  Public IP (endpoint)
my call flow from internet to local : call to public ip of expressway then using fallback alias in VCS-E, the call directed to an endpoint registered in VCS control.
In VCS-E, i already configure:
- search rule to VCS-C
- fallback alias to endpoint registered in VCS-C
- Traversal Server
- Static NAT
In VCS-C, i configure
- Traversal client
- Search rule to VCS-E
The signaling process run well (i can call to 1.2.3.4, endpoint in VCS-C ringing), but when i try to pick up, the call automatically disconected.
The reason is "New connection needed".
Did i miss something?
Any suggestion will be appreciated.
Anju Josua
Chris Swinney
Level 5
Level 5
Hi Anhu,
Do you have the Dual NIC licence on the VCS-E? You will need this (I believe) in this deployment scenario) and you will then set One of the interface to be on the Loacl network and one on the public/external network and allow the VCS-E to apply the NATing.
Chris
Hi Chris,
Yes, i already have that license.
Thx,
Anju
Anju Josua
Hi all,
i suspect my nat configuration still miss something.
is there any configuration related h.323 with NAT?
Thx,
Anju
Hi Anju,
NAT'ing should be done done via the VCS-E from the DMZ to public network (with the dual NIC option), however if there is a further NAT in place between the VCS-C and VCS-E, ensure that this is on a 1:to:1 mapping and the there are no additional H.323 Application Layer Gateways (ALG) running on the device between the VCS-C and VCS-E.
To test, you could place an endpoint logicically in the DMZ and register directly to the VCS-E (thus by passing the VCS-C). Does this call out correctly.
If not, then you may need to post of more deployment info such as a diagram or log capture, search results etc.
Chris
