VCS default root password
Louis-Alex
Here's the situation.  I'd like to get access to the log files written at /mnt/harddisk/log/ on my VCS.
The fact is that I'm new in charge, and don't know if the root pwd was changed (hope not !)...
I found a little procedure, which reset the pwd (by logggin with pwrec from the PC via a serial cable and all), but as the reboot of the device is kinda tricky I was first wondering if there was a default pwd which could be still granted?!...
EDIT
For now, I can access my VCS by using PuttY-SSH (by entering the IP adress) ...
The default password on most of these devices is TANDBERG (in caps).  Failing that, you will need to follow the pwrec process.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
