VCS/Expressway software
gUAno
Hi folks,
Yesterday I successfully downloaded sw x8.11.3 but today it is only language packs there. I am little bit afraid that Ciso found something in those packages and removed them.
Does anybody knows what happened, it is only x8.8.3 is availble per now . .
Best Regards,
Artem Borodai
5 Replies 5
Jaime Valencia
The documentation for all the releases is still available, I'd think there's probably something going on with the downloads site.
java
if this helps, please rate
dan.engelhardt
Is there a release date set yet for x8.11.4? I wasn't able to find anything in regards to this and the BUG description gives this version as the fixed version. We have a datacenter build scheduled to be in production in two weeks and cannot use such an old version as x8.8...
You'd need to reach to your SE to get that information.
java
Hi Dan,
Expressway/VCS X8.11.4 has been posted on CCO and is now publicly available.
https://software.cisco.com/download/release.html?i=!y&mdfid=283733603&softwareid=280886992&release=X8.11.4&os=
Shashank
