VCS Monitoring: Alerts
Paul Woelfel
Level 4
Level 4
I want to monitor the VCS and it's alerts. The VCS hast the same API like the endpoints: I can query the config and status via https://ip/getxml?location=/Status. This is very usefull and in combination with SNMP provides nearly all information I need.
The only thing I miss:
How can I get the alerts via HTTPS? These are not included in the Status.
Regards, Paul
mahkrish
Level 3
Level 3
Hi Paul, If you have a TMS in your infra managing the vcs then you can have the alerts.
Yes, we've got the tms, but we want to get that info in our monitoring system by pulling it from VCS or TMS.
Regards, Paul
Hi, I found it in the status, it is already included:
https://ip/getxml?location=/Status/Warnings
I just overlooked that.
Regards, Paul
Hi Paul, Thank you for sharing the update.
BR,Mahesh Adithiyha
