VCS Tandberg Lync 2010 integration question
albacom
Hello All,
situation: three Lync 2010 central sites (pool plus directors) and one VCS Lync gateway (two VCS clustered together).
Everything is running smmothly and users are happily enjoying integration features.
The problem arose when the customer introduced a SBA (Survivability Branch Appliance) in the configuration. Users homed on it are not able to enjoy the integration features (basically video calls from Lync clients and Tandberg stations do not work).
Can you please advise on the above?
Thank you in advance
beppe
Martin Koch
Just out of understanding, shouldnt you be "homed" on it only in the failure case?
The Lync documents I saw stated that this is a feature for enterprise voice.
So with both in mind I would say I am not surpised.
No,
That is your primary registrar. The secondary is the central site. Yes those users have enterprise voice. Do you know if a Lync infrastructure with central site and SBA can support integration features?
Cheers
beppe
Hello Albacom,
Did you get an answer of your question?  I have similar issue with VCS-Lync 2013 integration.
Thanks.
