vcs to tms agent communication problem
Archil Sokhadze
hello ,
with a member VCS from a cluster the communication with TMS Agent to Provision MOVI is disturbed. The Trial to keep this over TMS running failed all the times
12/5/2012 9:44:39 PM          Event Created
12/5/2012 9:44:41 PM          Event executed by TMS2
12/5/2012 9:44:41 PM          TMS agent data replication will be set up for the following system(s): smth.test.com
12/5/2012 9:44:41 PM          Reading local TMS agent status
12/5/2012 9:44:41 PM          Reading TMS agent status on 'smth.test.com'
12/5/2012 9:44:56 PM          Reading TMS agent status on 'smth.test.com' failed
12/5/2012 9:44:56 PM          Failed to enable TMS agent data replication for 'smth.test.com'
12/5/2012 9:44:56 PM          The event failed to complete. Details: TMS agent data replication setup failed for the following system(s): smth.test.com
The concerning VCS is showing under VCS Configuration -> Clustering -> View TMS Agent replication status:
No base DN's found.
There were several Reboots from TMS and VCS according to  "VCS cluster creation and maintenance Deployment Guide" for Verison 7.1 the Steps
Remove a live VCS from a VCS X7.1 cluster (permanently)
and
Add an X7.1 VCS to a VCS X7.1 cluster (TMS Agent legacy mode)
executed.
Magnus Ohm
Hi Archil
There is a good tmsagent troubleshooting guide in the documents here in the forum. Just search for tmsagent troubleshooting guide.
I also recommend going to tmspe. This error is seen for example when the replication password on the tms does not match the vcs. There are several scenarios in the document.
/Magnus
Tomonori Taniguchi
Are you selecting appropriate group name for “Base Group” in TMS Connection Setting under Provisioning tab?
This is group name that provisioning user account is mapped to.
If you are configuring provisioning account in default user group, then should be “root”.
Try uncheck all services and reconfigure parameters in TMS Connection Settings then click save and Force refresh.
Then re-check all services and click save.
